'07 infinty diagram
Old Nov 24, 2009 | 01:48 AM
luigi517's Avatar
luigi517
Default '07 infinty diagram
I need the wiring diagram for the head unit in an '07 1500 quad cab w/ the infinity system, I know its probably been asked a hundred times before but the only ones i can find don't quite match the colors in my truck.
thanks
Old Nov 24, 2009 | 08:36 AM
dirtydog's Avatar
dirtydog
Moderate User
06+ have diff wiring than prior years.
No nav.
2007 Dodge Ram 2500 Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
nav
Dodge 2006 Ram Pickup EX. CAB Pickup
(PREMIUM SYSTEM)
RADIO HARNESS Wire FunctionColorNoteFuse #SizeLocation+12V DC Battery(Constant)Gray/red Radio pins 1 & 12 11 20 amp Integrated power module at left front fender Switched AccessoryData Ground Black Also black/light green Left Rear + Dk.green/dk.blue Line level output Left Rear - Dk.green/orange Line level output Right Rear + Gray/dk.blue Line level output Right Rear - Gray/orange Line level output
AMPLIFIER OUTPUTS Wire FunctionColorNoteFuse #SizeLocation12V DC BatteryYellow/red Amplifier pins C1-4 & C1-13 36 25 amp Integrated power module at left front fender Remote Turn On (input) N/A See notes for B+ & accessory power to subwoofer amplifier. Left Front Mid + Dk.green/yellow Left Front Mid - Dk.green/lt.blue Left Front Tweeter + Gray/orange Left Front Tweeter - Gray/yellow Right Front Mid + Gray/yellow Right Front Mid - Gray/lt.blue Right Front Tweeter + Gray/dk.green Right Front Tweeter - Gray/lt.green Left Rear Mid + Gray/lt.green Left Rear Mid - Gray/dk.green Right Rear Mid + Dk.green/lt.green Right Rear Mid - Dk.green/gray Center Channel + Gray/brown Center Channel - Gray/orange Subwoofer 1 + Dk.green/tan To the subwoofer amplifier Subwoofer 1 - Gray/tan To the subwoofer amplifier
AT SPEAKERS Wire FunctionColorNoteRight Rear Mid + Gray/lt.green Or dk.green/lt.green Right Rear Mid - Gray/dk.green Or dk.green/gray Subwoofer 1 + Gray/brown Channel 1 of subwoofer speaker. Subwoofer 1 - Dk.green/brown Channel 1 of subwoofer speaker. Subwoofer 2 + Gray/white Channel 2 of subwoofer speaker. Subwoofer 2 - Dk.green/white Channel 2 of subwoofer speaker.
Available Notes Notes The SUBWOOFER AMPLIFIER, has B+ at pin 2 (red) with fuse no. 24 of 20 amperes in the integrated power module; the accessory line (pink/yellow) goes to pin 3 & has fuse no. 39 of 10 amperes.
The main amplifier is located at right side of dash, but the woofer amplifier is at left side of body.
Old Nov 25, 2009 | 01:28 PM
luigi517's Avatar
luigi517
Thanks, Can I assume the 2500 and 1500 have the same wiring? How can there not be a switched wire in the harness, it has to know when I turn the truck on somehow? and why does it only list 4 speakers when I have 7?
Old Nov 30, 2009 | 01:56 AM
luigi517's Avatar
luigi517
I just got back from vacation and looked in my truck, those are nothing like the colors in mine
Old Nov 30, 2009 | 06:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I can look at my Alldata when I get home but what exactly are you trying to do?
Old Dec 1, 2009 | 05:14 PM
luigi517's Avatar
luigi517
sorry I just found out about canbus, I guess those are post amp colors, I just need to buy the converter, sorry for the stupid question
