???02 ram rear window wont go up???
Old Dec 2, 2009 | 05:55 PM
RAM8686's Avatar
RAM8686
Default ???02 ram rear window wont go up???
I have a 02 quad cab and i put the passenger side rear window down and it wont come back up... I tried replacing the motor but still nothing from either switch... All the switches are working...
Im stuck!!! Please help!!!
Old Dec 2, 2009 | 07:34 PM
05RamMan's Avatar
05RamMan
start by determining if you are getting voltage to the rear window motor. If not you need to find the open. If you are, you need to look for things like corroded ground or splices.
Old Dec 2, 2009 | 07:50 PM
Cheat's Avatar
Cheat
Also If you need it to just go up find your power wires on your motor and tap into them and give it 12V manualy. That way you can atleast have a closed window?
