I have no heat??
Old Dec 3, 2009 | 07:23 AM
gtup's Avatar
gtup
Default I have no heat??
Well little to no heat... I found out that my truck while at idle has no heat it just blows out cool/slightly warm air, but if I am driving it heats up some, but not like it should. I have a 180 t-stat, and replaced my plenum gasket along with a tune up. What could be wrong here, all of my fluids are fine ect...
Old Dec 3, 2009 | 08:11 AM
HammerZ71's Avatar
HammerZ71
Did you have the 180* stat in last winter?
Old Dec 3, 2009 | 08:42 AM
gtup's Avatar
gtup
I bought this truck this spring so I have never had to use the heat, but I just replaced the t-stat a couple weeks ago when I replaced my plenum gasket...
Old Dec 3, 2009 | 11:23 AM
gtup's Avatar
gtup
Anybody? Could the heater core be bad? If so how hard are they to replace?
Old Dec 3, 2009 | 11:30 AM
HammerZ71's Avatar
HammerZ71
My first try would be to replace the thermostat with a normal temp one, would be a < $10 try. I know many guys who live in northern climates who use a 180* thermostat have to switch back to the stock one so they have enough heat in winter. You may very well find that's all it is.
Then if that didn't work I'd look more at a blend door/heater core type issue...
Old Dec 3, 2009 | 12:09 PM
gtup's Avatar
gtup
I checked the lines going to the heater core and the one one the left is really hot and the one on the right is warm but not has hot as the one on the left....
Old Dec 3, 2009 | 12:26 PM
gtup's Avatar
gtup
Could there be air in the heater core? If I flush my coolant would that help clear the heater core? When I changed my plenum gasket I had to fill my rad. up several times probably letting air in??
Old Dec 3, 2009 | 02:02 PM
hometheaterman's Avatar
hometheaterman
Maybe try flushing the heater core out and see if anything comes out. It may be stopped up.
Old Dec 3, 2009 | 02:11 PM
gtup's Avatar
gtup
If I take it somewhere to get a coolant flush it will flush the heater core also (at least thats what they told me..), so for 60 bucks I cant beat that. I just hope that fixes it.
Old Dec 3, 2009 | 02:19 PM
bigdodge2006's Avatar
bigdodge2006
i had the same problem and it was trash in the core and flushed it out myself with out losing hardly any coolant by pulling both hoses off and running water through one side. cheap way but worked
