05 RAM Keyless Entry Programing trouble
Old Dec 5, 2009 | 10:56 AM
ricaza's Avatar
ricaza
Exclamation 05 RAM Keyless Entry Programing trouble
I have been trying to program an extra keyless entry using the following instructions, I get up to step 3 ok, after I hear the chime I release the buttons and go to step 4. During step 4 I press any of the buttons in the remote but I do not hear any chime and it doesnt program the remote. Need help!
1. Turn ignition to the RUN position (as far as you can go without starting the engine).
Wait for chimes to stop.
2. Using original programmed remote, press and hold the UNLOCK button on the
remote for between 5 and 10 seconds.
3. While holding UNLOCK button, and before 10 seconds passes, press and release
the
PANIC button. A chime will sound to indicate that the transmitter programming
mode
has been entered.
4. Within 30 seconds of the chime, press a button on all remotes to be programmed
into the system including any previously programmed remotes, a chime will
sound after each remote has been programmed.
5. Turn the ignition OFF to exit the transmitter programming mode.
Old Dec 5, 2009 | 12:16 PM
dirtydog's Avatar
dirtydog
Moderate User
thePANIC button. A chime will sound to indicate that the transmitter programming
mode has been entered.
into the systemincluding any previously programmed remotes, a chime will
Try pressing the programmed romote button first followed by the new one. You must also be using a factory programed remote that's original to the truck in order to program any aditional one's. The FCC numbers on the back must match the OEM remote exactly.
