a/c & heater isn't blowing enough ?
Old Dec 6, 2009 | 04:10 PM
slagger's Avatar
slagger
New Member
Thumbs up a/c & heater isn't blowing enough ?
Hi All,
I just join today and I hope to be on this site a lot.
Well I have a 2003 hemi
it all started about 5 days ago when I started my truck I heard a couple of small clunking sound under the hood I fig it was my niegbors cat's because I have seen cat hair under my hood so they are sleeping under there so I started to drive to work and I notice my a/c blower was barley blowing after checking all the function's everything is still working right but it is blowing like it is on low but the blower is runing high?
you have heat,cold,up,down, and you hear the blower is on high but when you switch it from recir to reg it dose not change sounds.
you can feel the air blowing out the vents but really low and the blower is runing high.
do you guys have an ideal what it might be.
thanks a lot guys.
Old Dec 6, 2009 | 04:33 PM
dirtydog's Avatar
dirtydog
Moderate User
I think your just paying more attention now than before. My '08 screams on high but the cfm flow out of the vents doesn't feel like it sounds. It feels like it's on medium if that. Common Ram issue from what I have known.
I would use the Search function and search BLEND DOOR as that could be of issue.
Old Dec 6, 2009 | 11:00 PM
ramhead1500's Avatar
ramhead1500
Yes it does sound like the blend door. Mine did the same thing to, changed the blend
door and it works fine.
Old Dec 7, 2009 | 02:19 AM
slagger's Avatar
slagger
New Member
it happen from one day to the next big differants it barley blows any air
on the bland doors where and how do I get to them/
thanks guys.
