Blower only works on high
Old Dec 10, 2009 | 04:27 PM
ubacool12's Avatar
ubacool12
Question Blower only works on high
Can anyone tell me what might I check to determine why my heat/air conditioning blower only works in the last (highest ) switch position?
Old Dec 10, 2009 | 05:23 PM
rchapman721's Avatar
rchapman721
not sure if the rams have them, but i know the dakotas have a blower resistor that goes bad and does that.
Old Dec 10, 2009 | 09:05 PM
hemiraptor700's Avatar
hemiraptor700
Yea they have resistors and it happened on my cousins cummins and that was the cause, should be in fresh air tube under dash
Old Dec 10, 2009 | 09:27 PM
reefguy89's Avatar
reefguy89
might be the selector switch
Old Dec 11, 2009 | 01:15 AM
jchandler21's Avatar
jchandler21
heres what your gonna do...underneath the passenger side of the dash you'll see the blower. there should be a connector going into the housing. take off the connector and remove the the screws holding the resistor into the housing. Now sniff it or look for any noticable things wrong. If it smells burnt or looks like somthin is wrong replace it thats ur issue.
