Passenger Front Door window switch panel
Old Dec 17, 2009 | 01:22 PM
nh5's Avatar
nh5
Default Passenger Front Door window switch panel
When I pulled my door off a while ago replacing my front speakers, The bottom clip on the back of the little plastic panel piece that contains the lock and window switches broke so now when you try to control the window the panel slides and you can see inside the door panel then. Where can I get a replacement? Dealer only part I think? Maybe I should try a junkyard? Or glue it back in.
Old Dec 17, 2009 | 01:35 PM
Ice-Forever's Avatar
Ice-Forever
If it's something you could glue back in that's what I would do lol...Would be the easiest fix, and what's the worst that could happen? It doesn't work, THEN you can worry about finding a replacement
