03 Ram Quad tail light not working?
Old Dec 19, 2009 | 06:03 PM
etn's Avatar
etn
Default 03 Ram Quad tail light not working?
I have an 03 Ram 1500 quad cab and my driver's side tail light is not working. I have replaced all the bulbs, no change. The brake light is working, as is the turn signal, but the tail light does not. The passenger side works properly. Any thoughts?
Old Dec 19, 2009 | 07:17 PM
irelandshemi's Avatar
irelandshemi
i dont know much about it but maybe something with the board that controls the lights or something like that people were having problems with
Old Dec 19, 2009 | 08:17 PM
cwboyjohnny24's Avatar
cwboyjohnny24
I've heard about the board that controls the lights as well, but before i did that I would first check out the wires leading from the brake light back and check your ground and that none of the connectors into the light bar itself aren't corroded. Also, they may not be corroded where you see them, try jiggling the wires while someone holds the brakes and see if they'll come on for you. Just a thought.
