Ground Shaker Sub Box
Old Dec 25, 2009 | 01:29 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Cheaper and less trouble just to buy one unless you wanna make one just to say you did. Nothing wrong with that either.
Old Dec 25, 2009 | 01:31 PM
moosefire66's Avatar
moosefire66
He will be making the fox box again for the QC in early to mid January. I emailed him last week about it. He said he is behind and took it off the website so that he could try to catch up. And the new foxbox I believe is 2.0 cu. ft. of air space per sub, so much more air being pushed.
Old Dec 25, 2009 | 07:31 PM
EJM05's Avatar
EJM05
Im running two Kenwoods. But like everyone else said. Get a FOXBOX. I plan on buying one.
Old Dec 25, 2009 | 10:17 PM
Slap_my_momma's Avatar
Slap_my_momma
Originally Posted by weedahoe
definately recomment a foxbox.
www.foxacoustics.com
Ive got some pic of mine in the link in my sig
Hi ,
I went to your link and saw that you have what's called a PROBOX, is that the foxbox? It has fiberglass?
I went to foxacoustics.com and the only one it shows is model# DMC-210-DF
It states it is not made for the quad-cab or crew cab. Not sure, but I have an 2004 4-dr Ram (does this mean it is a crew cab?)?
http://www.foxacoustics.com/SearchResults.asp?Cat=23
BTW... I like that box with the fiberglass. Did you have to remove anything to make this box fit under the rear seats?
Thanks for sharing.
Old Dec 25, 2009 | 11:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Probox and Foxbox are two different boxes. Neither are made from fiberglass. The probox is MDF and the foxbox is ABS plastic.
