3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
so Santa brought me lights for my truck this year and they are the Hella 500's. 2 questions. I can't find the install link someone had posted a while back complete with pictures and step by step so....help? And whats the difference in the 500's compared to the 500FF?
Not the same pattern.........the 500 is a direct spotlight beam...the ff is more like a headlight - kind of a spread beam pattern. I recently switched to the ffs - they light bup more in my opinion.
Dirty, did you possibly have anymore pictures as far as that install in concerned....I have zero confidence when it comes to wiring LOL. And what's that small black piece just below the spool of 14ga wire?
i have no other pics. Lots of info in the text. That install is using a diff rocker switch powered diretly from the battery. Hella gives directions as well, but then you have to have your headlights on before the Hella's will work. i wanted them independently. i think Hella's install may be what you are looking for as most will have their headlights on when using their driving lights anyways.
That black piece is shrink tubing. I soldered and used shrink tubing on all of my connections.
