3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
That would be extremely expensive to change the entire hub. I think, and I may be wrong but you should be able to go online and look for an adapter that would go on your hub like a spacer where you could change the lug pattern from 5 on 5.5 to 6. Most adapter companies don't want to do that though. I would look at selling the rims and buying new ones for your truck. It would also be a lot safer to have a wheel that is meant for our 5 on 5.5" lug pattern.
