Any way to disable the 4,000 rev limit??
Old Jan 12, 2010 | 06:55 PM
EJM05's Avatar
EJM05
I was just wondering cause when I do rev it to show my exhaust note, it doesn't sound so great after 4k...
Old Jan 13, 2010 | 02:54 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Originally Posted by lxman1
No logical reason to rev an engine that high unless it is a manual trans and you are running slicks. Keep the rpm below 4K out of gear or the block may fail to keep the rods inside of it!!
shark frog and lx,
what causes this in the hemi? do you just end up floating the rod/piston, or is there something else with the motor?
Old Jan 13, 2010 | 03:05 PM
EJM05's Avatar
EJM05
So when people buy the superchips or the diablo and get rid of the rev limiter that is a bad thing?
Old Jan 13, 2010 | 03:07 PM
SilverBullet08's Avatar
SilverBullet08
they dont get rid of it, its raised but thats the rev limiter when you are at wot i believe
Old Jan 13, 2010 | 03:09 PM
EJM05's Avatar
EJM05
So I can raise it to be like 6000 instead of 4000 for being in neutral? All I want is to have the sound go a bit farther when I rev it. It kinda sound pathetic after 4000 when Im in neutral.
Old Jan 13, 2010 | 03:14 PM
cyclone429's Avatar
cyclone429
once I hit 4500 RPm, I bounce of the rev limiter, I have a 6sp, wounder if automatic hemis have less of a rev limiter, now I'm not racing the engine at a stand still, but when I play drade racer in 3rd and up, I can pull 4500 rpm with stock tune.
Old Jan 13, 2010 | 03:38 PM
xfeejayx's Avatar
xfeejayx
you can NOT raise it past 4K in park/neutral even with a superchip
Old Jan 13, 2010 | 03:46 PM
EJM05's Avatar
EJM05
Ok thats all I need to know. I thought I saw a video out there on youtube with a guy with a ram with the rev limiter gone or raised. Ill see if I can find it again.
Old Jan 13, 2010 | 04:00 PM
nim81's Avatar
nim81
at WOT i hit about 6K before a shift on the interstate, but not an inch past 4K in park. and i have raised rev limit with SC. just went and checked.
Old Jan 13, 2010 | 04:07 PM
EJM05's Avatar
EJM05
Wait so you have raised it in park/neutral?
