2003 oxygen sensors
Old Jan 16, 2010 | 04:35 PM
joeylead's Avatar
joeylead
Default 2003 oxygen sensors
I've been getting a code or o2 sensors. It says bank 1 sensor 2. (P0138) My repair manual shows 4 sensors for 2 catalytic converters so it should be the 1 after the cat on the drivers side. When I got under the truck, I only saw 2 sensors. It looks like the pipes go from each exhaust collector to a single cat and there is 1 sensor before and 1 sensor after the cat. Am I missing something?
My truck is a 2003 hemi 4X4 quad cab. Thanks for any help with this.
Old Jan 16, 2010 | 05:07 PM
HammerZ71's Avatar
HammerZ71
Yeah, sounds like you are missing one cat and two O2 sensors...
Most, if not all 03s and some of the early 04s had a single cat setup. Its the 02 AFTER the cat...
Old Jan 16, 2010 | 09:58 PM
joeylead's Avatar
joeylead
thanks for the info. I sort of figured that I wasnt totally crazy here! Im glad that I wasnt about to change the wrong one! Which is good, because the one before the cat is a bit harder to get at anyway...lol!
