Long Tubes Installed! (Now with a Video)
That is with the cutout open, and it gets a lot louder when I give it some gas. Those vids are basically me just cruising when I go past the camera. A WOT video will be coming soon.
Sounds exactly the way mine did when I had mine with no cats and running to lean, raspy and airy....
Not that it sounds bad, just a little off. Once you get a wideband installed and adjust the fuel trims a little to make up for running lean it should sound a bit better and more aggressive.
Yes, a wideband will help me get it dialed in to where I need it but unfortunately I won't have one for another month. There won't be any tuning in the near future though unless SC can help adjust my fuel trims (which some guys said they have done for them). If not, I will just have to wait till this summer when I try a tuner stack.
The guys I talked to said that SC will need a data log of A/F and rpms to make the changes. Which means that I need to get the wideband in there to get the logs and then see if SC will hook me up.
