mod opinions??
Old Jan 20, 2010 | 08:37 PM
rollingdodge's Avatar
rollingdodge
Default mod opinions??
i just bought a 2003 ram 1500 4x4 with the 5.9L i put a k&n intake and exhaust in it so far. was looking at getting the superchips flashpaq. is there anything else or something different that you think i should get first for around the same price? im looking for more all round power torque and hp. let me know what you think i should do. thank you
Old Jan 20, 2010 | 09:08 PM
cheapbeater's Avatar
cheapbeater
superchips 3815 is a good start, i hear they really wake those 5.9's up... where in wi are you located?
Old Jan 20, 2010 | 09:12 PM
SMKNRAM's Avatar
SMKNRAM
the SC tuner will really impress you. get a CAI and a high flow exhaust with a 180* t-stat and it will wake that 5.9 right up!!
Old Jan 21, 2010 | 12:19 AM
rollingdodge
in the richfield/ germantown area. and is there a difference between the 3865 and the 3815 SC. just because thats what they said to use on there website? probably just new vs. old i would imagine. and ik this probably sounds stupid but what difference does the t-stat do?
Old Jan 21, 2010 | 12:45 AM
rcman0056's Avatar
rcman0056
The thing with mods is you never really appreciate them if you do them all at once. Drive your truck around for a little get used to it and then add a mod. CAI. then a little later an exhaust and such.... Do everything at once and the enjoyment of "new" and "exciting" lasts a limited amount of time.
Old Jan 21, 2010 | 12:47 AM
dave-o's Avatar
dave-o
save your money to spend on gas
Old Jan 21, 2010 | 01:20 AM
cheapbeater
the 3865 is the newer version that will allow you to control the transmission shift points, etc... BUT only '04? + rams will get these options. the trans computer is seperate on the '03 hemi, and you have a completely different tranny with the 5.9... so... just get a 3815, you should be able to find an unlocked used one cheap since everyone with the newer trucks will be selling them and buying the 3865 for the trans options...
Old Jan 21, 2010 | 02:33 AM
Brokenpath's Avatar
Brokenpath
headers and full exhaust setup
That's just me though. Look under your ram sometime at the exhaust manifold before the cats. bugs me everyday thinking about it when i step on the gas.
Old Jan 21, 2010 | 07:38 AM
SMKNRAM's Avatar
SMKNRAM
3865 is the only one for 5.9 that I know of! That is what I have. When you do the CAI and a better flowing exhaust with the performance tune it will cause the engine to run a little lean. If you run a 180* t-stat it will make the computer think it needs to richen it up, so it will offset the lean caused by the MODS. Also whenever you do any of these MODS you need to reset your ECU and basically retrain your computer with the new data. In the end your seat dyno will say WOW!!!
Old Jan 21, 2010 | 10:40 AM
rollingdodge
ok well i think im just going to go with the 3865 just to be on the safe side. and i was looking at some other post about a TMR delete mod? i tried looking for this on my truck but i believe the trans is different because i cant find the computer anywhere. yeah i looked at the manifold before it is pathetic. ha i might have to make a new one. im going to wait on the headers for now.
