Sway bar end links
Old Jan 25, 2010 | 06:39 PM
rugsapjr's Avatar
rugsapjr
Default Sway bar end links
New guy here looking for info on sway bar end links. I have a 2006 1500 4WD SLT. I had a local garage install a 3" leveling kit, now the links are stretched out and angled too much. Has anyone else had this problem?
Old Jan 25, 2010 | 08:25 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Old Jan 26, 2010 | 10:36 AM
jball's Avatar
jball
You can get a sway bar drop bracket kit for up to your frame or new links. You probably only need to drop the sway bar 1-2 inches to get it back to a decent angle. You could even make your own out of some rectangular tubing and drilled some holes.
I don't know if anyone makes a direct 'factory style' replacement link that is a little bit longer. You could convert your links over to an eye and eye style (with adapter brackets) or eye and stem style. I made some for my buddy when his factory ones became blown out.
I bet the stems on your sway bar links are starting to bend or will shortly....
