Some problems with the frontparts
Old Jan 28, 2010 | 05:12 PM
JONKEN's Avatar
JONKEN
Default Some problems with the frontparts
Hi there, have a little problem with the truck as I am sure you can answer.
1: When I run with four-wheel drive and turn I hear a whining sound from the front, what is it that allows that? wheel bearings? certainly a common problem ... With 2 wheel drive can not hear at all.
2: The shock absorbers leaking oil so I ordered the new Bilstein dampers coming soon so I wonder if there is much work to change? needed no special tools or pass it with sockets? Otherwise I leave it to the workshop.
Has also skewed brake but it will probably be no problem to change.
Will be fine when everything is exchanged =)
/ JONNY
