Faulty code question.
I get a code: P 1491 (radiator fan relay). My question is can still drive with that faulty relay? Or I should change it as soon as possible? And also can somebody explain to me how to check if relay is the problem?
Thanks
Thanks
We need more info: What year and engine Ram do you have? I believe Rams have always used a mechanical engine cooling fan, so you should be OK to drive it. The only electric cooling fan i'm aware of on these trucks are the A/C condenser fans. Check to make sure you have power to the relay, if YES, replace relay. If NO, find out why there is no power to relay.
Is this code from your Ram or a car? Like Nightrunner said, these are mechanical fans run off the motor so the only fan you have is on the ac. Unless you've put an e-fan on yourself.
