3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
On the way home from work the other night my front windows were cracked open slightly and when I closed them the headlights dimmed slightly. I messed around with the switches and when I would open or close either the front or rear windows I noticed it. I tried it again last night and it did the same thing. Anyone else have this happen to them? I am wondering if it is the begining of a larger issue. (hope not).
Thanks.
compleatly normal dont loose sleep man . just check your battery and alt ...charging system make sure your battery isint weak. but 98% vehicals do this no biggy
