question about the column shift lever
how does the end of the shift lever come off? does it screw off, bolt off, slide off? and how could i relocate the OD button? reason being is i have a set of novelty brass knuckles and i wanna attach it to the end of my shift lever. kinda like a shift ****, but for a column shifter ya know...
Get yourself a big pair of channel locks. Remove the button from tow/haul button from the end first. and then grab a handful of channel locks and begin twisting. The end is splined on, and don't plan on re-using the original **** once you remove it. I did this, and can now use any universal shift **** on the end of the column lever. I relocated the tow haul button to the Cig lighter hole in the dash, and like the ay it looks. The housing for the button fits the hole perfectly, just route the wires through the side of the lighter, reconnect and you're done. I'll see if I can get pics later.
