Window Problems
Old Jan 29, 2010 | 09:44 AM
korby05's Avatar
korby05
Default Window Problems
Alright here's the problem...I noticed around xmas eve when I was coming home from work that my Back Passenger window wouldn't go down on the switch on the drivers door... When I got home I unlocked it and tried from the switch in the back and it worked...I was going to take the door apart to see if it was a loose connection but it's been cold the for a while.
If the switch itself is bad do you guys know where i can find one at other then the stealership.
Thanks
Old Jan 29, 2010 | 10:29 AM
Deviate's Avatar
Deviate
There have been a few threads about issues like this. I have had a problem where mine will stop working for all windows, including the driver's. What you may find to be the issue is the lock mechanism on the master switch. Some guys have reported that if they just disable that lock switch completely it resolves the problem...of course you can't lock the window switches for the other doors then.
Here is a link for the catalog page at LMC where they have the switch: http://www.lmctruck.com/icatalog/de/full.aspx?Page=26
