Power lock and Remote Keyless Entry problem
Old Jan 31, 2010 | 10:40 PM
Gumby008's Avatar
Gumby008
Angry Power lock and Remote Keyless Entry problem
After my RKE quit working, I attempted to reprogram it using the instructions in the owner's manual and with several different sets of instructions I found on the internet. One way called for using a paperclip to jump a pin on the Data Link Connector. I believe I jumped the wrong pin. I got a small spark. Now, I have no radio. My working Fob only works when the key is engaged, also the door lock switch on the door panel only locks and unlocks the doors when the key is engaged. When the key is out of the ignition, I cannot turn on the interior lights, and the headlights do not stay on like they did before once I turn off the key. All of the lights and signals are operational as are the wipers at all intervals, and the cruise control. Does anybody have an idea what the problem is? I would appreciate any help or suggestions. Also I did try removing fuse #19 and turning the key on.
