Exhaust Question
Old Feb 1, 2010 | 11:29 PM
mopower05's Avatar
mopower05
Default Exhaust Question
I have a 2005 dodge with a 4.7. I am wanting to have true duals installed but every exhaust shop in town is telling me it can not be done. I have explaned to them that i have to stock cats with o2s but they keep telling me that it will cause the truck to run like S&%T and it will set off the check engine light. Someone please help.
Also i am thinking of buying a programmer to gain some HP and help with MPG, any suggestions.
Thanks in advance!!
Old Feb 2, 2010 | 11:35 PM
hoidsracing's Avatar
hoidsracing
depends on your definition of "true" duals is. for true duals you would come off of each manifold, go to an x or h pipe, to two different mufflers then exit how you want. or you could run without the x or h or mufflers for that reason lol. most likely you would have to re-run the entire exhaust system, sounds like they just don't wanna tackle the job.
you could just run a single in dual out muffler with dual exit pipes. would be cheaper and you wouldn't come anywhere close to messing with the cats or O2's.
Old Feb 21, 2010 | 07:17 PM
rocket23's Avatar
rocket23
I agree with hoid I'm putting in flowmaster 50 I don't need the burly look n listen sound that bad . I do want to eliminate useless excess resonators/mufflers I also feel I won.t sacrifice engine porformance with just the upgrade I realise I'm decreasing back pressure but not too the degree of loss of performance.
