2wd leveling kits 05
I've been lookin for a nice leveling kit (even 4" suspension lifts" for my 2wd single cab truck for a while now, everything has an if, and, n' but to it. Like kit can only be used with quad cabs, or 4x4, or cannot be used with stock tires, anyone know a smooth riding leveling kit or small ( no higher than 6") suspension lift kit out there?
Thanks in advance!
Thanks in advance!
Are you looking for something larger than say a 2" leveling kit? How high do you want it? The problem with going any higher than say 2 or 3" is that you'll be changing out the spindle most likely and to make the tires not rub on your suspension components you need an aftermarket rim with atleast 4.5" of backspacing.
it explained it cannot be used because of back spacing, and i'm not sure what that is or what i'd need to change my wheel to too avoid rubbing.
if you don't want to replace your stock wheels with aftermarket ones with the proper offset and backspacing, then use simple, inexpensive wheel spacers.
I'd not recommend them for a serious off-roader or hauler, but for general use, they are fine...
http://www.roughcountry.com/dodge_2wd_02-05_3.html
I'd say something like this. It does say you have to have 4.5 " of backspacing on your rim, but I do believe that that's only because of the size tire they're suggesting. I'm sure you could run that on your stocker's. Just for the simple fact you're not changing the factory spindle. I have their 2" coils and didn't have to change rims. You may call them and ask if you're interested in a kit.
Yeah a 2wd to fit 35's you are going to need a 6 inch lift.
A 4wd you can do 2 inch lift to "Fit" 35's
Trending Topics
i'm looking for a decent one because i treat my truck like a truck, not a toy. i don't go mudding what so ever or haul extremely heavy loads but i do rough it up a little bit because it CAN handle it. so buying a to simple one i think would be dangerous for the chances of it sucking that bad.
i found this cheap 3" suspension
http://performancelifts.com/cgi-bin/cart/CSCDX2.html
but, what i don't understand or trust is the fact that it has a picture of a single cab when when i read the details it says it only fits a quad cab
and also i beleive 3" will fit 35's even on a 2wd, found the info on this site from https://dodgeforum.com/forum/3rd-gen...d-fitment.html
edit : and also read somewhere rough country lifts ride was uncomfortable.
hence the name "rough country" i guess
i bought the 3" lift from rough country off autotrucktoys.com, have yet to put it on, it'll go on with the new wheels and tires late march/earlier april (when the snow and salt is gone)
and my trucks a work truck too
