03 ram starting trouble
Old Feb 2, 2010 | 11:26 AM
creepjohnny's Avatar
creepjohnny
Question 03 ram starting trouble
I did a thread search and found similar posts but they were a but different so maybe you guys can answer or fill me in on what's up!!
2003 ram 1500 5.7 hemi 96,500 miles 2wd
Never had trouble starting, this morning, it's about 53 degrees out, and my truck is under a car port. So it's not in direct cold. Turn kEy and it took a few extra cranks than it usually does to start, but it starts then dies. Then I turned the key again and the starter just cranked, engine didn't catch. Tried again and starter was cranking, I pushed the gas pedal and it started but was very rough, and after a minute ran ok. Then it ran fine to work, and I parked and stopped the engine, and tried restarting it and it started fine.
So what happened this morning? Two days ago and the past years it always fired up and never had starting problems.
Is it needing a tune up soon? This is really the first trouble I've had so if you had similar troubles let's hear it!!
Old Feb 2, 2010 | 11:34 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Have you cleaned your throttle body yet? Also, how long has it been since you changed your plugs. It may be time to do a good once over tune up and see how that works for you. You may also make sure your battery is fully charged.
Old Feb 2, 2010 | 01:15 PM
AF_HEMI's Avatar
AF_HEMI
If its turning over but not catching, its either a fuel or spark problem. My guess is spark plugs, but possibly clogged injectors as well. do an overall tune up. Change out the sparkplugs, clean the throttle body, poor some injector cleaner in the gas tank next fill up, and you should be ok.
Old Feb 2, 2010 | 01:45 PM
creepjohnny
Cool! Thanks guys. What is the usual tune up mileage on these trucks?
Old Feb 2, 2010 | 01:49 PM
cwboyjohnny24
A good number thrown around here is 30,000 miles for plugs. So I would say while you're doing that every 30,000 just check up on everything else.
Old Feb 2, 2010 | 07:03 PM
creepjohnny
Will do cowboy! I'll get ya an update when I can check these
plugs out. I think I'm going to look for the champion copper plugs, I hear those are the best unless you think there is a better plug. Also what's this I hear about turning ur car on off on off and you get a display? I never heard about this
Old Feb 2, 2010 | 07:53 PM
cwboyjohnny24
The key trick to get your truck check engine codes?????
https://dodgeforum.com/forum/3rd-gen...ine-codes.html
Old Feb 3, 2010 | 01:34 PM
creepjohnny
thank you for the forum like, cowboy!
latest update, got work work yesterday, and at the end of the day the truck started like nothing happened. and same with this morning.
truck is messing with me, but I'm gonna do a routine check up on everything to keep this bad boy running great.
Old Feb 3, 2010 | 01:59 PM
cwboyjohnny24
Glad to hear she's running ok for you. I think the 'ol girl just wants some mods so she was being a little b!tchy. hahaha Good luck!
