Train Horns Anyone???
Old Feb 12, 2010 | 11:21 AM
  #21
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by 05RamMan
Weed, Do you ever run tools off your compressor setup, Aka, Air wrench, Impact or tire inflator?
3
I do, I keep an air hose in the truck with a impact gun and air chucks
Do you leave your tank filled all the time?
I do. Usually full at 200psi
Do you have it set for Key-on power or on all the time?
It is wired straight to the battery but I have a switch in the dash to turn it on. I left it straight wired once and it cut on one night while I was asleep. The pressure switch failed to turn off the compressor and the inline circuit breaker I had failed so it ran all night until the batteries were dead. Since then I added the switch.
How many blows do you get before the compressor has to kick in?
Depends on how long you hold it down but with 1/2 valve you push some air pretty quick. Overall, I would say 30secs of full blowing time.
Do you know What kind of draw does the compressor in startup ?
IDK off hand but Im sure ViAiR has it on thier site
How loud is the compressor?
Not too loud but you can heat it running. I have it mounted on rubber bushing to keep the vibration noise down.
Do you know Whats the CFM rating of the compressor?
IDK, but again, Im sure Viair has it on thier site
Can the compressor be safetly mounted upside down or does it have to be right side up?
It can be mounted it any position
More importantly, Are you happy with your setup?
I am happy with mine. Ive had it a good while now and never any issues
More interested in the compressor airtank setup, the air horns are a side beneifit.
Again, I keep air tools and hoses with me just in case I need them
I wonder if we could get someone on here and to give us a discount.
Good luck on that one
Old Feb 13, 2010 | 03:29 AM
  #22
05RamMan's Avatar
05RamMan
Thanks Weed. I will be picking one up soon.
Old Feb 13, 2010 | 03:54 AM
  #23
RedTruck-VA's Avatar
RedTruck-VA
It ain't a train horn but a 139db boat horn on my VTX1800. Will make a car jump lanes (main street), folks pee their pants (Walmart) and put a dump truck in a ditch (country road). I won't go into specific's, but it work good... I also think it boils the gas in the gas tank, so it's best not to lay on it to much.
