2002 dodge pick-p/u
Old Feb 12, 2010 | 02:12 PM
TjTazz's Avatar
TjTazz
Default 2002 dodge pick-p/u
The "no bus" code strikes again.
My Truck was plowing for 22 hrs straight and died out of no where. I have a 2002 Dodge Ram V/8 manum ext. cab p/u with an 8" bed pushing a 7 1/2' western minute mount plow. Bought used in 2005, never a problem till recently. First the tranny lost reverse & had to rebuild with a h/d shift kit. Next came the headlights, lost the low beam, Brights worked but the low beam didn't. Had to replace the ground wire @ the module. Most recent is the infamous "no bus", after turning off the truck while refueling we started the truck and after putting it in drive and gave it gas it stalled.
Old Feb 12, 2010 | 04:48 PM
TjTazz's Avatar
TjTazz
I've been working on this thing all day, I got the gauges to work and hear the fuel pump kick on after wiggling the wire harness clip on the right side of the computer but still can't start it. Any advice is greatly appreciated.
Old Feb 15, 2010 | 07:37 PM
Kingsnap's Avatar
Kingsnap
I read on a previous post that a person reconnected the harness to the steering column. Maybe a unplug and replug?? I believe that was in the GEN2 section.
