Truck Sputter
Old Feb 15, 2010 | 08:17 PM
rbrumm's Avatar
rbrumm
Default Truck Sputter
OK I know there are alot of posts about this but none seem to be the same, or at least I haven't found one. The truck is an 02 5.9 L gas with 107,xxx. Lately when the truck is cold it will sputter and have no power for a short distance say 1/4 mile, and if it is babied it will come out of it and work normal. Sometimes even during a warmup it will idle low and missfire. Once the truck is warmed up it doesn't seem to happen. Any thoughts?
Thanks
Old Feb 15, 2010 | 08:21 PM
dirtydog's Avatar
dirtydog
Moderate User
no codes huh?
How bout the plug wires? Moisture could be an issue if they are cracked and would cause the hesitation problem. You can measure the resistance of them to see if they are good or not, but if they are original its time for new one's anyways.
Old Feb 15, 2010 | 08:31 PM
ramhunter9's Avatar
ramhunter9
i agree with dog, 100+ miles on the same plugs/wires lol you got your moneys worth bro.
Old Feb 15, 2010 | 10:03 PM
rbrumm's Avatar
rbrumm
Should have mentioned I did the wires, plugs, rotor and cap about 7000 miles ago but never thought about moisture in the cap.
Old Apr 24, 2010 | 01:17 PM
rbrumm's Avatar
rbrumm
If I shut it off during the sputter and start right away again the problem is gone! Not sure what to check. Moisture in the cap would not go away with restarting, so must be sensor or something...anyone have any further thoughts. No codes so not sure where to start.
Old Apr 25, 2010 | 10:39 PM
rbrumm's Avatar
rbrumm
Took off the air intake tube and started the truck. Started fine, sucked air pretty hard with the butterflies closed. Built up some vacuum and idled for about a minute. Then it started sucking sputtering and sucking air really bad, kinda like it couldn't breath, butterflies still closed. Shut off and restarted and idled fine. No problem the rest of the day. WTH
Old Apr 26, 2010 | 06:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Have you checked all the vacuum lines for leaks?
