steering column
Old Feb 15, 2010 | 10:42 PM
jimaire's Avatar
jimaire
Default steering column
How do I remove the plastic around the steering column on my 02 Dodge 1500? I have a loose wire in the column that powers the fan motor that I need to repair. Thanks
Old Feb 16, 2010 | 05:44 AM
RedTruck-VA's Avatar
RedTruck-VA
The upper and lower plastic shrouds are screwed together. Pull the screws and seperate carefully. The manual recommends disconnecting the battery to avoid accidently setting off the airbag while working on the steering column.
Good luck..
Old Feb 16, 2010 | 09:03 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
They are t-10 torx BTW I think and you will need a torx screwdriver. A bit will not fit in there. There should be 3 you have to remove,
Old Feb 16, 2010 | 10:18 AM
jimaire's Avatar
jimaire
Thank you guys. I appreciate the help.
