Does it or Does it not?
Old Apr 25, 2005 | 08:06 PM
kharding20's Avatar
kharding20
Default Does it or Does it not?
I have read various posts that says changing to a magnaflow, flowmaster or any low restriction exhaust will take away low end power on the hemi's because of no backpressure. Is this true or not? I am still a bit skeptical about changing after reading these posts. Any info will help.
Old Apr 25, 2005 | 11:57 PM
magnum v8's Avatar
magnum v8
Default RE: Does it or Does it not?
I'm far from being an automotive expert, but I've read that when you change the piping from a single to dual, or vice versa, you can lose back pressure. That was posted on a thread about the 4.7's. So, I can't be for sure about the Hemi's. I can't believe that a higher flowing muffler will do any harm. Anything that makes your engine breath easier should only be a benefit.
My advice: check with a dedicated muffler shop or certified automotive technician.....that you trust.
John
Old Apr 26, 2005 | 02:08 AM
horatio102's Avatar
horatio102
There's a difference between a bigger or dual pipes and less restrictive muffler. A less restrictive muffler will allow gasses to flow faster at all speeds, whereas a larger pipe will effectively slow the gasses down at lower speeds, causing a loss of low-end power. I'm not going to post my reasoning yet again, but if you search recent exhaust threads (flowmaster) it's out there.
Old Apr 26, 2005 | 02:18 AM
horatio102's Avatar
horatio102
It was still on the first page even. Give this a read: https://dodgeforum.com/m_192213/tm.htm
Old Apr 26, 2005 | 03:49 PM
RedRam225's Avatar
RedRam225
For what it's worth, I replaced the muffler on my 3.7, not added duals or changed the pipe in any way, just new flowmaster. The sound is very sweet; no loss of power. It seems I may have picked up some power, but that also may be just because it sounds soooooo nice!
