gear change???
Old Feb 17, 2010 | 10:26 PM
2006RamCrazy's Avatar
2006RamCrazy
I put the 4.56 in mine along with a TransGo 545RFE Shift kit at the same time and I am very happy with the performance improvements
Much more get up and go from a stop and will spin the 20's (Crappy OEM Goodyear's) right off if I'm not careful...
Please be aware that wet weather traction on the OEM tires is non-existent with this gear.. I spin from almost every light I pull away from no matter how I try not too.
I NEED DIFFERENT TIRES BADLY!!!!
good luck
Old Feb 18, 2010 | 01:48 AM
2003ram4.7's Avatar
2003ram4.7
ok ware can you get the shift kit??? and while i have the rear end appart, should i put a locker in it too?
Old Feb 18, 2010 | 01:56 AM
Shiloh 24's Avatar
Shiloh 24
For on road use I would put in like a DTT or Auburn, if you love playin in some soupy freakin mud or like to go rock crawling get an ARB airlocker or E-lock.
Old Feb 18, 2010 | 02:21 AM
Animal Mother's Avatar
Animal Mother
4.10s seems to be the gear of choice for 4.7's other places i read
Old Feb 18, 2010 | 03:26 AM
rickof08's Avatar
rickof08
I have 4.56's and 31in tires and my gas mileage got better in town and the same on highway, and i drive long distances on the highway. Your truck will thank you for it especially on hills! lol
Old Feb 18, 2010 | 05:25 AM
2006RamCrazy
Save your money and get the stage 2 or 3 VB from Moe's then find somebody like KRC Performance who can reprogram the PCM trans points..... The kit isn't too spectacular after 10K go by..... The computer learns the higher pressures and adjusts shifts to the softer side...
Old Feb 18, 2010 | 11:07 AM
chambers's Avatar
chambers
Guys the OP has an nv3500 manual tranny. So a couple things to remember are his overdrive ratio is 0.73 vs. 0.67 on the automatic and w/ 4.56's and 33's at 70 he would be turning about 2400 rpm where the auto would be about 2200 rpm. Now w/ 4.10's at 70 he would be 2133 rpm which is pretty much the same as the auto w/ 4.56's.
Old Feb 18, 2010 | 10:00 PM
2003ram4.7's Avatar
2003ram4.7
alright guys, thanks for the info. 4.10s and a DTT seem to be the best choice for my truck ill keep ya posted on that
