urgent!!!!!!!!!
Old Feb 17, 2010 | 02:00 PM
gredmond3410's Avatar
gredmond3410
Default urgent!!!!!!!!!
will 305/55r20's fit on a bone stock 2007 ram 1500 2wd?? i can't find a definitive answer and i hate to buy them online and not have them fit...i want to buy them today but no one will give me a straight answer, I've even called half a dozen dealerships. please help, thanks.
Old Feb 17, 2010 | 02:01 PM
gredmond3410
they are nitto terra grapplers...
SilverBullet08's Avatar
SilverBullet08
must have not searched that hard bc that answer is here. check the faq section but they will fit. its a shorter tire than the stock size...
Old Feb 17, 2010 | 02:07 PM
gredmond3410
its the width that i'm worried about and i know you guys hate the same old q and a but i promise you i have searched. 305/55r20 will be ok on my truck? again the info is greatly appreciated.
Old Feb 17, 2010 | 02:11 PM
SilverBullet08
yes like i said they will fit
https://dodgeforum.com/forum/3rd-gen...rformance.html
Old Feb 17, 2010 | 02:15 PM
mdram43's Avatar
mdram43
they might fit, but you should definitely consider atleast a leveling kit. I have the same tires on a set of 20s i have, and ive also got a 3" rough country lift waiting to go on. I put them up to my truck and there is not much room to play with in the front, so on a speed bump you will definitely rub your front wells
Old Feb 17, 2010 | 02:46 PM
gredmond3410
yeah i have a leveling kit waiting at home 2" daystar...i'm in Houston until the end of February but i need new tires...as long as they do ok till i get to Tampa i'm golden. Thanks for the help and the info. My 07 is patriot blue as well...great color right? After i get the level and tires i'm going to snap a few and post em on here, i've only been a member for like 2 weeks. lotta great trucks on here.
Old Feb 17, 2010 | 03:51 PM
Ice-Forever's Avatar
Ice-Forever
They would fit not with a level. I ran those tires before these 35s
Old Feb 17, 2010 | 05:30 PM
mdram43's Avatar
mdram43
you mean they would fit without a level? and your a 4x4 which sits several inches higher than a 2wd
Old Feb 19, 2010 | 07:48 PM
gredmond3410
i just got back from 4wheel parts with the new terra grapplers, 305/55r20. They fit great, no rubbing even at full turn. When i get back to florida im outting on a 2" level and 1" rear block...ill post some pics soon. thanks for all the help. fyi i got them installed out the door for $1198(balance, tax, mount, etc.). i called the 800 number on the website and haggled the salesman, Wayne.
