Aftermarket HU to Infinity RAZ wiring
Old Feb 17, 2010 | 11:07 PM
itsahemi4x4's Avatar
itsahemi4x4
Default Aftermarket HU to Infinity RAZ wiring
I read on here that the standard radio harness will work for an aftermarket HU insall, but will you retain sound out of all 7 speakers. Someone said there is a blue wire that needs to be connected, but to what? Im looking to buy and install this myself, but would like to retain the factory amp and all 7 speakers. Any help is appreciated. Thanks
Old Feb 18, 2010 | 12:18 AM
Marx's Avatar
Marx
blue wire is the amp turn on wire, should be able go get a wire harness that will more or less colour match everything
Old Feb 18, 2010 | 12:37 AM
itsahemi4x4
can i jump the amp turn on wire to a power antenna wire from the aftermarket head unit, and avoid buying the amp integration harness and rol with the standard stereo installation harness available just about anywhere?
Old Feb 18, 2010 | 12:40 AM
Shiloh 24's Avatar
Shiloh 24
Hook your amp wire up to the accessory wire, easiest would be to splice into the cigarette lighter beside the cup holder.
Old Feb 18, 2010 | 12:56 AM
itsahemi4x4
Thanks for the help.
