truck stalling
Old Feb 20, 2010 | 12:00 PM
west59's Avatar
west59
Default truck stalling
I have a 2003 1500 truck, the battery died and had to replaced one end of the battery cable, now when you put the truck truck in park it stalls every time and sometimes it will stall when you shift gears any guesses what it could be
Old Feb 20, 2010 | 12:30 PM
BEAR's Avatar
BEAR
More info would be a help...Engine? You say shifting gears...you mean going from R-N-D or you talking manual?
Old Feb 20, 2010 | 07:48 PM
west59's Avatar
west59
4.7 liter auto and yes when shifting, always stalls when going into park and occasionally when shifting between R-N-D
Old Feb 21, 2010 | 10:34 AM
sabedra211's Avatar
sabedra211
are u getting any codeS?? check engine light.. U should replace ur throttle position sensor and clean ur throttle body. how much miles ur engine gotS?
Old Feb 21, 2010 | 10:47 AM
cwboyjohnny24's Avatar
cwboyjohnny24
First I would make sure that your battery wires are tight on both ends. Then if that's not the case maybe look at the neutral safety switch?
Old Feb 21, 2010 | 10:51 AM
dirtydog's Avatar
dirtydog
Moderate User
Is your alternator charging properly? What is your idle at in park and drive when it's not stalling?
So this didn't happen prior to the battery change? ever?
Old Feb 21, 2010 | 12:14 PM
west59's Avatar
west59
No check engine light, if i did the code right, not sure, it said donE, never had a problem before, and the it is charging fine, the idle is fine when start up and in drive
