Custom Tune Question
Old Feb 21, 2010 | 01:30 AM
truckin151's Avatar
truckin151
Default Custom Tune Question
Just curious, what parameters can be adjusted within a custom tune? More specifically what can be adjusted using the diablo programmer?
Old Feb 21, 2010 | 01:42 AM
chefred112's Avatar
chefred112
in our 05's..almost anything with a diablo...datlalog the following an lotsa stuff can be manipulated..
ACT (F) or IAT
ECT (F)
OPEN LOOP FA (AFR)
RPM
MPH
1/1 Long Term ADAP(%)
1/1 Short Term ADAP(%)
2/1Long Term ADAP (%)
2/1 Short Term ADAP(%)
Baro (PSI)
PRATIO (PRatio)
AVG Total Working PW (us)
KNK Sensor 1 (V)
KNK Sensor 2 (V)
KNK TOTAL RETARD (DEG)
MAP TO USE (psi)
RAW TPS 1 (V)
RAW TPS 2 (V)
ACTUAL SPARK CYL 1 (DEG)
ACTUAL SPARK CYL 2 (DEG)
ACTUAL SPARK CYL 3 (DEG)
ACTUAL SPARK CYL 4 (DEG)
ACTUAL SPARK CYL 5 (DEG)
ACTUAL SPARK CYL 6 (DEG)
ACTUAL SPARK CYL 7 (DEG)
ACTUAL SPARK CYL 8 (DEG)
BASE SPK (DEG)
THROTTLE BLADE POSITION (%)
Old Feb 21, 2010 | 02:15 AM
truckin151's Avatar
truckin151
So would it be possible to adjust the throttle sensitivity or advance it through a custom tune?
