315/70/17 ?? Will they fit?
Old Apr 26, 2005 | 09:16 PM
mikegonzo0351's Avatar
mikegonzo0351
Default 315/70/17 ?? Will they fit?
I have a chance to buy these tires and get them mounted for 750. Will they fit a 2005 dodge Ram 4x4. They should fit the stock rims right?? HOw about clearnce. Please lemme know asap.
Oh yeah BFGoodrich All Terrains
Thanks
Mike
Old Apr 26, 2005 | 10:11 PM
hmipwrd's Avatar
hmipwrd
Default RE: 315/70/17 ?? Will they fit?
you could go to TIRES.com, you can select your vehicle and will tell you what sizes will fit. otherwise call a local tire shop. hope this helps.
Old Apr 26, 2005 | 10:44 PM
05hemi's Avatar
05hemi
They should fit the stock rim. The only thing that I would be concerned with is tire rub when you turn. I don't think this should be a problem with the 4X4
Old Apr 27, 2005 | 07:04 PM
RebelRam04's Avatar
RebelRam04
Most places I've seen don't recommend anything larger than a 305 on a stock ram but you might get lucky and not rub, doubt it. As far as fitting the rims, check the tire specs, the factory rims are 17x8 most tires I've seen over 305 take 9" wheels, especially M/Ts. You might get away with A/Ts on both points since the tread is a less agressive lug pattern.
Old Apr 27, 2005 | 07:45 PM
tommiwan's Avatar
tommiwan
If you have a 1500 I wouldn't do it. I think they would fit on a 2500 just fine, but not 1500. I have 305's on my 1500, and I can tell you for sure that there is no rubbing, but at the same time, there isn't a lot of room left. Any higher than 305 and you will rub.
