Issues removing dash
Old Feb 23, 2010 | 06:57 PM
Trishafer's Avatar
Trishafer
Default Issues removing dash
The heater core on my ram cracked several months back and I have just gotten around to trying to replace it. I've drained my coolant, removed my glove box, dropped my steering, and removed several bolts around the dash in an attempt to get to my heater core but I seem to be missing some bolts somewhere that are preventing me from pulling the dash back. Does anyone know of a diagram or something that will show what bolts or screws are holding the thing together? I just want some heat!
Old Feb 23, 2010 | 06:59 PM
Trishafer's Avatar
Trishafer
Its a 2002 Dodge Ram 1500 btw
Old Feb 24, 2010 | 07:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I can pull the info out of Alldata later for you when I get home if no one else has gotten it for you by then.
Old Feb 24, 2010 | 01:31 PM
Trishafer's Avatar
Trishafer
If you could that would be AWESOME. Thank you so much
Old Feb 24, 2010 | 07:37 PM
mike_r's Avatar
mike_r
Will you post that info? I'm curious on how to get to the amp in that area.
Old Feb 24, 2010 | 08:30 PM
Trishafer's Avatar
Trishafer
Talking I found something glorious!
I found a line hiddin within several other links within several pages of links far past google. (If that gives you any idea how hard this was to find!)
The dodge service manual for the 2003 dodge ram is located at http://www.ossh.com/dodge/03DRM.pdf
The dodge service manual for the 2004 dodge ram is located at http://www.pdfdir.com/dodge/2004-ram...1500-2500-3500
These are the DalmlerChrysler certified service manuals and be careful not to print unless you are REALLY sure you need to print all 2895+ pages of the manual.
I have yet to find a manual for the 2002s and it doesn't look like I'm going to but I don't think they could have changed too terribly much from 2002 to 2003 or 2004.
Oh and you will need Adobe to read those fyi.
Old Feb 25, 2010 | 08:48 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
second link doesnt work. Well it does but its not the Srvc Man.
Old Feb 25, 2010 | 01:44 PM
Trishafer's Avatar
Trishafer
down at the bottom click "Next page" and it continues to the service manual.
Old Feb 25, 2010 | 02:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Not for me, it download a small PDF and you can click on the bottom right but then says the rest of the manual cannot be found
Old Feb 25, 2010 | 02:40 PM
Trishafer's Avatar
Trishafer
http://www.ossh.com/dodge/19078-dr_intlpdf.pdf
try that. it works fine for me.
did you ever find the information for the 2002?
