Transmision pan
Old Feb 23, 2010 | 08:00 PM
ccgRAMrod's Avatar
ccgRAMrod
Default Transmision pan
Looking to buy a aftermarket trans. pan that holds more fluid, who makes one? Also anyone heard of changing there torque converter in the 5 speeds?
Old Feb 23, 2010 | 08:03 PM
chefred112's Avatar
chefred112
PML... I have an edge 2800 stall tq vertor on mine..
Old Feb 23, 2010 | 08:07 PM
HammerZ71's Avatar
HammerZ71
PML, Mag Hytech...
Old Feb 23, 2010 | 08:15 PM
OlDirtyJohn's Avatar
OlDirtyJohn
there are quite a few companies out there that make aftermarket trans pans for our trannys. I have a PML pan on the way, holds more fluid, its cast aluminum, and has fins, magnetic drain plug, and ready for a temp sensor. there is also MAG-Hytec. those are super nice, but a little pricey. most aftermarket parts places carry them, i ordered mine from moesperformance.com
Old Feb 23, 2010 | 08:17 PM
OlDirtyJohn
oh yeah, and converters. quite a good performance gain to be had. some of the better known companies for converters are Edge (im running an Edge 2400) APS, and Circle-D. im sure there are more out there, but those are the ones i hear about most.
Andre over at Edge has some of the best customer service i have found anywhere!
Old Feb 24, 2010 | 04:25 PM
ccgRAMrod's Avatar
ccgRAMrod
Ok next question... what tranny do we have I mean the ID#? I have a '03 2500 with the 5.7 if that matters.
Thanks
Old Feb 24, 2010 | 06:43 PM
OlDirtyJohn
you have the 5-45RFE. make sure you do your research on the trans pans though. some will not fit on the 2500s without exhaust modifications. on the 2500's the exhaust pipe routes right underneath the trans pan on the rear portion. you can alleviate this problem by dropping the exhuast an inch or so though.
