Bak Flip G2 for Dodge Ram Short Bed
Old Feb 26, 2010 | 12:15 AM
mparvin's Avatar
mparvin
Default Bak Flip G2 for Dodge Ram Short Bed
Hi y'all. Wanted to let y'all know about the deal I received for a Bak Flip G2 on Ebay. Ebay is using this "Best Offer" type of selection instead of the bidding type. I looked up this G2 bed cover for $687.64 from realtruck.com. I used the Best Offer button for $600.00 and they accepted it along with Free Shipping.
Just to fore warn you though, once you use this option, you are obligated to buy the item. I was cool with it, because I haven't seen any other place selling them lower. I tried going lower to $550 but it wasn't accepted. I should be receiving it soon. Hopefully it's a great deal and a good product. Thanks y'all.
Ebay Item-G2 Bed Cover
Old Feb 26, 2010 | 12:21 AM
rocket23's Avatar
rocket23
dunno if its a hard top or not? looking for one thats hard and cannot be cut.
Old Feb 26, 2010 | 12:35 AM
mparvin's Avatar
mparvin
Default Yeah it's a Hard Cover.
G2 BakFlip Hard Folding Truck Bed Cover.
FITS:
Dodge Ram Short Bed 6'3" Bed 2003-2008 also fits 2002 1500 Model
Questions Call 7-Days a week at 1-877-216-5446
G2 Generation 2 Upgrades: Newly designed rubber side sides, reinforced panel frames, which are 3 times more robust that have integrated drain chanels under them as well as a new modular latching and locking system for optimum performance. Plus a newly designed locking arm that keeps the cover up and allows you to drive with cover up if needed.
Full Truck Bed Access: Bakflip allows FULL ACCESS to all stake pockets and works with tie downs, bedcaps, bedliners, bedrails, lumber/ladder racks and bed extenders.
Secure: The BakFlip cover easily locks offering outstanding security
Versatile: Individual panels lock so that you can drive with them open or closed. Panels flip open in the same direction. Panels flip open to reveal 100% of the bed if desired.
Fast Install & Quick Removal: BakFlip clamps onto your truck bed with no drilling and installs in approximately 10 minutes with just one wrench INSIDE the truck bed rails for an EXTREME low profile look and fit and can be removed with in 60 seconds. The Flip Bak truck bed cover can be completely removed in 60 seconds. Locking knurled ***** have replaced simple nuts for easy tool-free on and off capabilities. The average cover weighs 35 lbs and can ship UPS.
Strength & Rigidity: Made from dual laminated ABS panels with honeycomb core of excellent tensile strength and rigidity.
UV Protected: The BakFlip is UV protected and will not fade, crack, warp, rust or corrode and the texture of the product perfectly matches door handles, bumper trim, side view mirrors and bedcaps. Absolute all season friendly – resistant to rain snow and the elements.
Easy To Open: Panels flip open in the same direction to reveal 100% of the bed if desired, can withstand over 200 lbs of evenly distributed weight and locks for outstanding security
Protection: The BakFlip cover protects your rear window when completely open – perfect for loading things like ATV’s, motorcycles or any other goods that might damage your window.
Accessory Friendly: BakFlip works with tie downs, bedcaps, bedliners, bedrails, lumber/ladder racks and bed extenders.
Extemely Low Profile: Bakflip sits INSIDE the truck bed rails for an EXTREME low profile look and fit.
Premium Finish: The texture of the product perfectly matches door handles, bumper trim, side view mirrors and bedcaps.
Premium Fit: The Bak Flip cover is custom built for each application for a OEM like fit. BakFlip G2 gives you access to *******ly all of your truck bed without removing the cover! The BakFlip Panels flip open to reveal 1/4, 1/2 or all of you truck bed! The cover folds in one direction, and all panels lock into place against the back of the cab. When the BakFlip is folded up, it protects your rear truck window from your cargo. The BakFlip works with all makes of bed extenders. The Bakflip can be unlatched from the driver's or passenger's side.
Generation 2 of the BakFlip tonneau bed covers feature newly designed rubber side seals that attach with tongue and groove, rather than tape. Reinforced panel frames that are 3 times as robust and have integrated drain channels under them, so there is no necessity for tape ANYWHERE. BakFlip covers are made of multiple panels. These panels automatically lock as you close them. The only way to release these hard folding panels is to pull on a latch cable secured under the cover. Doing so will allow you to fold each panel forward. When the panels are closed you cannot open the cover without access to the under-side of the BakFlip panels
For more information Call 7-Days a week at 1-877-216-5446
Old Feb 26, 2010 | 04:08 AM
Totti's Avatar
Totti
hey, that´s good to know!
i would like to buy one too, but i have to calculate the shipping costs to germany in, anything that helps me to get these thing cheaper would be great!! Thanks for the information!!!
