Tranny fluid used as an engine cleaner?
Old Feb 27, 2010 | 04:49 PM
John  M's Avatar
John M
Originally Posted by Gone Fishin
If you use synthetics oils, this gets done the whole time you're using it, assuming that it gets changed at good intervals.
Why would you think that synthetic oil functions as a detergent? It's simply a lubricant with more robust qualities.
Old Feb 27, 2010 | 06:49 PM
Gone Fishin's Avatar
Gone Fishin
If you do a search on the DF, check out the guys that have run dino oils in their 4.7 for a long period of time, then decided to change to synthetic engine oil. All the wax and sludge comes to the pan all at once and plugs their inlet screen.
The synthetics are not only good at lubricating, and lasting longer, they keep the inside of your engine, near spotless.
