Whats your psi
Old Mar 8, 2010 | 07:43 AM
  #21
weedahoe's Avatar
weedahoe
Hall of Fame Member
IDK, what does it say? Lower will get as more soft ride and a high tread wear and less MPG
Old Mar 8, 2010 | 08:00 AM
  #22
BEAR's Avatar
BEAR
As a rule I run about 80% of the max PSI that is written on the side of the tire.
Old Mar 8, 2010 | 08:59 AM
  #23
truckin151's Avatar
truckin151
305/50/20 40+/- in the front, 35+/- in the back, at the track 32 in the back gives the best traction/launches
Old Mar 8, 2010 | 12:21 PM
  #24
kx250frider617's Avatar
kx250frider617
I run 55 psi in my terra grapplers with E rating. max is 80.
I think following the door jam is stupid because what if a guy puts a D rated tire on his 3500 that calls for 70 psi but the tires max is 45 psi. I can see if the truck was stock but I always follow the actual tires measurement.
Old Mar 8, 2010 | 02:47 PM
  #25
DodgeThunder's Avatar
DodgeThunder
True, I worked in a tire shop for a couple years after school and I never used to go by the door stickers.. always what the tires recommend..
Im running 44psi in my 315/70/r17 just normally, when im 4x4ing I go down to 15 - 20 psi depending on what im doing with the truck..
Old Mar 8, 2010 | 11:26 PM
  #26
03MopaRamman's Avatar
03MopaRamman
Pro-comp Xtreme At 305/65/17 (claim to be 32.6 but actually 32 even)
Recommended PSI is 50, You don't want them to sag) Really smooth ride.
I lowered them to 45 in winter as these tires are brutal on ice when your running more torque the normal joe. (gotta keep revs in overdrive under 2 Thow RPM too).
Old Mar 9, 2010 | 10:45 AM
  #27
canadian wheeler's Avatar
canadian wheeler
Originally Posted by caliboy@heart
I'm runnin 305/70/17's on my stock 17's. What PSI should I be at?
about 40 psi
Old Mar 9, 2010 | 12:01 PM
  #28
DodgeThunder
Sorry to hijack but where abouts are you in BC canadian wheeler?
Old Mar 9, 2010 | 12:50 PM
  #29
davb673's Avatar
davb673
Factory 275/60R20s, I run 37 typically. Too many bumps around here for the wife. For highway, I sometimes bump it up to 40. All four corners are the same.
Old Mar 9, 2010 | 01:16 PM
  #30
toxdoc's Avatar
toxdoc
Wink
4x2 QC running 42psi cold on 305/45/22 all the way around.
