Level kit ?
Old Feb 28, 2010 | 04:56 PM
Jram47586's Avatar
Jram47586
Default Level kit ?
Is there 2 different ways to level our trucks out? I have seen the keys all over the place but have also seen a spacer that should fit on top of the coil. Are both of these methods for our trucks or is it on or the other. Btw i have an '05 4x4
Old Feb 28, 2010 | 04:59 PM
Desert_Ram's Avatar
Desert_Ram
your 4x4 you will need the keys!
Old Feb 28, 2010 | 05:00 PM
Jram47586's Avatar
Jram47586
So I guess that the spacers are for 2wds then?
Old Feb 28, 2010 | 05:20 PM
RiverBooty's Avatar
RiverBooty
I have an 09 Ram 1500 4x4 and had an inexpensive lift/level kit installed. It's a Rough Country kit that lifted the front 2.5" and the rear .75". The kit cost about $130 and includes strut spacers and coil spacers, no keys. You can check it out on their website, roughcountry.com.
Jim
Old Feb 28, 2010 | 05:22 PM
Jram47586's Avatar
Jram47586
That kit is only for the 09 and up. It doesnt list it for the 05s
Old Feb 28, 2010 | 06:02 PM
Desert_Ram's Avatar
Desert_Ram
i believe for 02-05 4x4 they use the keys dont mark my words as i have a 2wd witch uses the spacers
Old Feb 28, 2010 | 06:03 PM
Matt99's Avatar
Matt99
06up uses spacers/lift struts and yours uses keys
Desert_Ram's Avatar
Desert_Ram
there u go!
http://www.suspensionconnection.com/...tion/to=r.html
Old Feb 28, 2010 | 06:05 PM
Desert_Ram's Avatar
Desert_Ram
thanks matt for chiming in i was pretty positive but then again i have a 2wd and not a 4x4 so i dont research them to much!
Old Feb 28, 2010 | 06:06 PM
dodgegirl05's Avatar
dodgegirl05
i have a 05 2500 and i found 2" spacers on ebay cheap!
