Old Aug 5, 2015, 12:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
What mods do you regret getting?
Old Mar 3, 2010 | 06:38 PM
  #61
jroy's Avatar
jroy
You're putting more tension on it, the opposite of disabling it. It's not possible to max it out just by cranking the stock keys but it is possible with leveling keys which gives you a very rough ride.
Old Mar 4, 2010 | 12:15 AM
  #62
sbsga's Avatar
sbsga
the ride is better once you put the relocation brackets in with some longer shocks. the problem is the shock is fully extended most of the time. when the truck dips in a bump it comes back up and fully extends the shock causing a very undesired rough ride. also when you put torsion keys on it will change the wear angle on the ball joints and cv axles, which in turn will cause the axles and joints to wear within a matter of months. and if you plan on raising the back end at all be prepared to replace the pinion bearing and cup within a couples months too seeing as the torque angle changes causing wear angle changes.
Old Mar 4, 2010 | 01:12 AM
  #63
mmstar23's Avatar
mmstar23
on my gasser...i regretted over the rail bedliner.....
the new truck, i regret going with 4" exhaust....quickly switched that out for 5".....nothing like throwing money away
Old Mar 4, 2010 | 03:18 PM
  #64
BadHab1t's Avatar
BadHab1t
wow this turned into a pissing match and you told me "not in the what mods do you regret thread"....its not a how much do i know about torsion keys thread....
Old Mar 4, 2010 | 03:54 PM
  #65
Markmm0000's Avatar
Markmm0000
it turns into a pissing contest when someone states the obvious.
Old Mar 4, 2010 | 04:21 PM
  #66
SMKNRAM's Avatar
SMKNRAM
Dare I say... the only thing I regret is aftermarket tortion keys......
When I could have gotten the same LEVEL out of stock keys! And i think that is what you are both eluding too! Yes you can probably go higher with some aftermarket keys, BUT it will shred your cv's.
SO who is next with regrets!!!!
Old Mar 4, 2010 | 04:48 PM
  #67
Mega-Hemi's Avatar
Mega-Hemi
I bought a TB spacer when I was like 17-18, got screwed on my first eBay mesh grille, douche bag sent me chicken wire cut to fit in the grille. Other than that, I wish I hadden't just dumped $800 worth of exhaust into my 5.9 then traded it bout 3wks later. But, in my defense, I had no plans at the time to trade it.
Old Mar 4, 2010 | 05:49 PM
  #68
jroy's Avatar
jroy
I'd take the $800 loss to get a mega cab.
Old Mar 4, 2010 | 07:31 PM
  #69
Beastro's Avatar
Beastro
Originally Posted by rocket23
best mod thats easy dodge ram n/runner. Worst mod, friggin seat covers that gave more static and even stuck too denim jeans. ( couldn't slide on them) Hated them covers looked better in the box...
do you get a lot of static on your stock seat also is it just the fabrice? Everytime I get out and touch the door i get shocked!
Only regret cranking the stock torsion keys threw my alignment out bad. And grill inserts they didn't line up
Old Mar 4, 2010 | 10:59 PM
  #70
AsphaltCowboy's Avatar
AsphaltCowboy
why's that? im getting mine done tomorrow morning over the rail line-x. ive already scratched it to hell putting coolers in the bed over the side.
