need your opinions/ testimonials
Old Mar 2, 2010 | 11:44 AM
senselesscreationz's Avatar
senselesscreationz
Default need your opinions/ testimonials
which is the better kit in your opinion? anyone running any of these kits and how you like it and which one are you running?
http://www.rockymountainsusp.com/dodge4_02-03gas.htm
Old Mar 2, 2010 | 12:00 PM
HammerZ71's Avatar
HammerZ71
I run the Rancho 4" kit and love it! STRONG kit, replaces a good many front end components with nice oversized, beefy parts.
The Skyjacker also has a good reputation for taking abuse, if you want 6". It's also the ONLY kit that will clear 37s (if you are foolish enough to run them on an IFS front end) with out modifications.
Stay the hell away from the Fabtech and Superlift kits, both companies are in financial difficulties and the design is far weaker. Crossmembers as opposed to boxed sub-frames, etc. They also significantly weaken the CVs by increasing the angles that they must work at.
My Rancho, for example, retains the stock angle...
Old Mar 2, 2010 | 12:08 PM
senselesscreationz
ok if i may ask, the kit your running, how much higher does it make the front end then the leveling keys? and what did you run in the back blocks or your go a different route with add a leaf?
