02 Ram & Viper 5601 remote start
Trying ti install this 5601 in my 2wd 02 Ram. When I hit the key fob start button, dash lights come on, fuel pump comes on, no starter engage. If I put the keys in the ign, turned to ign, the remote start works.
What am I missing?
(Some specific alarm wiring questions, if someone here is familiar with viper)
Does the red/black H3/9 30a fused accessory/starter relay input alarm wire need to be hooked to 12v constant?
same for the H3/2 red/white 30a fused ign2 / flex relay input 87 ?
When I hook H3/2 to constant 12v, the H3/7 pink/white ign 2 flex relay output shows 12v constant regardless of the alarms state.
Also if I give 12v constant to the H3/9 red/black alarm wire the starter engages on its on. No keys in ign, no touching key fob?
What am I missing?
What color key do you have? It sounds like you need a bypass module that will allow the truck to start without the key! Go to www.xpresskit.com and put in your truck data and it will tell you which one you need! Also, check out www.the12volt.com for more help. I just installed a Viper 5901 on my 06 and these sites helped a ton!!
