Esp
Old Mar 4, 2010 | 01:09 AM
Invigor's Avatar
Invigor
Default Esp
I have an 07 hemi with that "ESP". Anyone know if a guy can disable it or is that something I am going to have to deal with?
Old Mar 4, 2010 | 06:23 AM
RedTruck-VA's Avatar
RedTruck-VA
ESP... Whats that?
Old Mar 4, 2010 | 06:47 AM
JoeHemi's Avatar
JoeHemi
Electronic Stability Programme.
Theres a couple threads about it here already and supposedly theres a key trick to turning it off on the 4X4s. Mostly in the 4th Gen section though. Have you tried any of these techniques? I know they arent Ram specific but it may help point you in the right direction.
http://www.jpmagazine.com/techarticl...tem/index.html
http://noesp.com/
Old Mar 4, 2010 | 11:48 PM
ballmart's Avatar
ballmart
Its traction control, its another way for Dodge to prevent you from having fun.
I used to have a charger and if you turn the key to ignition (cranked all the way) when the truck is rolling at 30 mph and hold it for 3-5 seconds, it would turn it off. I dont know if that works with a ram though
Old Mar 5, 2010 | 01:49 AM
PETE_YK's Avatar
PETE_YK
Im sure theres a loop hole like that for the ram. A guy i know had a f-150 and once he hit the speed limiter he turned the key to START 3 times and watched the speedometer climb some more!!!
