Valve Cover Bolts
Old Mar 5, 2010 | 02:11 AM
mmstar23's Avatar
mmstar23
the one valve cover that has not been painted/prepper
the bolts from the other valve cover, that have been removed. theres 2 different types...
Old Mar 5, 2010 | 02:17 AM
RamGentry13's Avatar
RamGentry13
huh..ok well heres my thought process...in the first pic the middle bolt looks like a stud to me. in the second pic the right bolt also looks like a stud with some weird grommet or spacer. Now when you put the calve cover back on look at any accessories the might sit or use a strut/blot&nut combo to attach itself to the valve cover. i dunno if that makes any sense but im gonna have to go look now! haha
Old Mar 5, 2010 | 02:20 AM
mmstar23's Avatar
mmstar23
i was thinking the same...after seeing the wires run across the top of your cover...has to be something like that lol..... what a PITA....this is why you take pics before hand!!
you also have an 07.....wonder if theres a difference between that and an 02
Old Mar 5, 2010 | 02:24 AM
RamGentry13
there might be a slight difference but i bet it has to do with something similar to what we concluded. hold on took a couple of quick snap shots to show what im talking about
Old Mar 5, 2010 | 02:30 AM
RamGentry13
My finger is pointing to the "stud"
Clostest bolt is the stud and second in the bolt. the wire loom has a clip for the studs.
I bet you have some clips that will clip onto the studs
Old Mar 5, 2010 | 02:46 AM
mmstar23's Avatar
mmstar23
ok....cool thanks.....im still gonna try and find a diagram of some sort. but if worst comes to worst then ill just sit there and match it up acording to the connections on the wires.
Old Mar 5, 2010 | 02:52 AM
RamGentry13
prolly need to track down some torque specs too but anyways good luck and post pics when done.
Old Mar 5, 2010 | 02:50 PM
mcgoo89's Avatar
mcgoo89
You figure it out mm? Cause I have an 02 4.7 and I can snap pics in the morning for you if you'd like
Old Mar 5, 2010 | 03:13 PM
mmstar23's Avatar
mmstar23
just got out of class, so i havent done anymore researching...i dont have the truck with me, just the valve covers, so its kinda difficult to line it up.... if one of you guys could maybe fill in the blanks for me, that would be great. im gonna draw up a diagram and see if one of can fill it in with a S for short, or L for long type of bolt
Old Mar 5, 2010 | 03:30 PM
mmstar23's Avatar
mmstar23
