weird rubber burning smell
Old Mar 7, 2010 | 02:19 AM
I DRIVE A HEMI RAM DAMNIT!'s Avatar
Default weird rubber burning smell
Im experiencing a hot rubber smell..and it pissn me off! I start the truck and drive to the gas station and get out and it smells like hell....smells like hot rubber. no leaks or nothing..then I drive it around for a couple hours..OD off..and no smell..could it just be the heads and motor and everything warming up? It is like..20 outside if that. The tranny isnt as responsive at first..then after i drive it and its hot and if I drive it in OD off for a while..it hooks up good. WTF over! Ok,im done ranting!
Old Mar 7, 2010 | 02:35 AM
RedTruck-VA's Avatar
RedTruck-VA
Are you saying you think the rubber burning smell and the trans OD on/off are related? Have you looked under the hood to see if there is anything burning. Cold outside, Heavy battery drain to start. Maybe charging heavily. Battery terminals clean and tight?
Old Mar 7, 2010 | 03:20 AM
Marx's Avatar
Marx
could be a stuck pully on your belt
Old Mar 7, 2010 | 10:42 AM
i know if could be anything...it jus pisses me off. ive looked...battery is good n tight..everything appears ok..ill have to get a bettter look...cause it only lasts a little while when you stopp...then its gone
Old Mar 7, 2010 | 12:47 PM
shortburb's Avatar
shortburb
The exhaust on my truck gets pretty close to my spare tire....I get a rubber smell too but I figured the exhaust was heating the spare.
Old Mar 7, 2010 | 01:12 PM
rumblebeef's Avatar
rumblebeef
I Had a pulley replaced cuz the bearing went after I soaked it trailing. Made an annoying whine, covered under warranty. Never had a burning rubber smell, but I get a strange smell when I first turn the heat on in the morning. Could it be a dead pulley, or just your heater?
