headers
Old Mar 9, 2010 | 02:00 PM
1badhemi07's Avatar
1badhemi07
Default headers
is there a do it yourself on how to install headers. like what parts other than the anti seze and mopar gasket. what else is there needed
Old Mar 9, 2010 | 02:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Someone did one some time back but I cant remember who? But other than the bolts, anti-sieze, gaskets and hand tools, thats all you need. You would want to soak the original bolts with PB Blaster or other penetrating oil though.
Old Mar 9, 2010 | 06:40 PM
1badhemi07's Avatar
1badhemi07
Ok so buy them 8 bolt from moes and get mopar gasket and use anti seze do I need any other parts
Old Mar 9, 2010 | 07:10 PM
Markmm0000's Avatar
Markmm0000
dont you need a whole new exaust? i thought aftermarket headers dont line up with the stock exhaust?
Old Mar 9, 2010 | 07:25 PM
HemiPro_05's Avatar
HemiPro_05
it depends on the headers... shorty headers will bolt right up. If you get mid-length I think you have to cut and weld once on each side. Lt's youll pretty much need a new exhuast but its worth gettin one anyway cause of the factory Y
Old Mar 9, 2010 | 07:45 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can get those Stage 8 locking bolts from Moes but they arent cheap. I just put on my drivers side header (LT) tonight before it got too dark and will do my pass side tomorrow after work. But I got my grade 8 bolts from a local hardware store for less than $5 for all 17 of them
Old Mar 9, 2010 | 08:09 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
If you are going LT's then you are going to need some more parts to make a system that the headers will connect to.
Old Mar 22, 2010 | 11:40 PM
moparmike01's Avatar
moparmike01
ya i got a cat back exhaust and a new y pipe
Old Mar 23, 2010 | 03:58 AM
abarmby's Avatar
abarmby
I have read that those "locking" header bolts are expense but once fitted, you never have to worry about them unscrewing and needing re-tightening again.
Something to bear in mind, if you don't want the chew of having to go through the worry about stripping threads in the heads etc.
Al.
Old Mar 23, 2010 | 10:40 AM
moparmike01
ya they are the stage locking bolt i just wanted make sure i did not need anything else
