Extremely Annoying Noise Help
Old Mar 11, 2010 | 07:57 PM
bchap05's Avatar
bchap05
Default Extremely Annoying Noise Help
I have a noise which sounds like it is coming from the dash. I have torn the dash apart 3 times now taking off most of the plastic and can't find it. I have driven around with the dash torn apart and reached around trying to find it. I have tightened any bolt that I could find and sprayed wd40 on everything that looked like it might squeak. Noise is sort of a creek/squeaking in noise.
It happens when turning or if I hit a bump on the driver side. It doesn't have to be a hard turn I can turn slightly and make it do it. It seems to be the loudest when I hit a bump such as a pothole that jars the front drivers side tire. It also seems louder when it is cold outside.
When the truck is stopped I can turn the wheel all I want and it won't make the noise. I can also open the door and rock the truck and it won't make the noise, only when moving. It sounds like its inside, I have stuck my head out the window and it definitely sounds like its inside.
Any ideas? I've tried most everything I can think of and its really driving me nuts.
